labview right-click memu dispear instead of staying
I'm using LabVIEW 7 on a XP Pro machine. Everytime I right click on either the front panel or disgram. The palette appears and when I release the button it goes away. Outside labview (eg, IE), the popup menu stays there unless I make selection or click some place else. Anyone know how to fix this? Thanks.
(2,738 Views)
I originally had that problem occur all the time. I also run LV7 on XP-Pro.
I re-installed LV7 on a new PC and it works fine. I was having many other problems with LV7 on the previous PC (Dell), which motivated me to re-install it on another machine (Clone).
Did you try re-installing both LV & Win-XP Pro?
-JLV-
(2,738 Views)
Reinstalling labview solved the problem, but I was looking for a way without reinstalling anything. It took long time to uninstall and reinstall labview.
-Joe
(2,738 Views)
I know...
But a man's gatta-do whatta man's gatta-do...
(It's all part of the fun...)
(2,738 Views)
