labview robotic module: configure properties of robot joints
hi
am working with labview robotic module in order to command a robotic arm, so i import the CAD model to the environment simulation module builder, then i make joint between each two parts and i associate a motor for each joint, but actually i couldn't configure the properties of each joint ( properties are mentionned in screenshots below)
if someone can explain for me these properties (scale,feedback,Fmax,fudge factor,bounce, CFM, lo Stop,Hi Stop,stop ERP,Stop CFM,rate),are these properties caracterize my motor?
(2,629 Views)
Hey Med_khalil94,
I would take a look at the following link, LVODE Properties and Methods, and that should explain each property you asked about. As far as I can tell, that is the extent to our documentation on these properties. Let me know if you have any followup specific questions!
Timothy D.
Applications Engineering
(2,590 Views)
thanks for ur reply
but in this link i couldn't really find an explanation for these properties, i only find how to read/write these properties..but my question was : what are the properties?for example ''fmax" is it the maximum force which can be supported by my motor ? are these properties caracterize my motor in reality? i only want to get an explanation of these properties
thanks
(2,586 Views)
