labview robotics
hello everyone, i try to implement the a* path planning. i just wnt to ask, how can i create the map like the picture below? i really need help.... help me please....Untitled.png
(4,519 Views)
What have you already tried? Is there any code behind your image, or did you draw the white paths on top of an array of booleans?
(4,494 Views)
i get the code from the A* example....i wnt to learn so that i know how  to create  map for A* path planning...
(4,459 Views)
(4,454 Views)
It is a 2-D boolean array.  You just need to place a 2-D boolean array on your front panel, and start clicking away at the LED's to make your paths.  Be sure to right click and save the values as default before saving your VI.
(4,451 Views)
