labview runtime broken 5.1.1
I created a 'development' library file with labview development that includes ALL sub vi's. When I try to run it with runtime it says a sub-vi is not executable. I open it back up with development just fine and re-save it. It is still broken with runtime. I have labview development 5.1 and runtime 5.1.1. Any ideas?
(2,801 Views)
Hi Stee1hed,
You can use runtime to run executables. They aren't used to run development VIs or .llb files. In your case, i think you are creating a llb file with all the sub vi's by saving with options, you are not creating a executable. To be able to use the runtime you could create a executable and include all the subvi's or the llb as support files.
Hope this helps,
pravin
(2,801 Views)
If you create an exe without any labview files in it (it's only about 43k), the resulting exe file is runtime and when ran it will bring up a file dialog to find the labview file you want to run. You can select a vi or llb from here for runtime to execute. It's abstract but has worked always before now.
(2,801 Views)
