labview runtime - slow pc start up
Here, this should work for 32 and 64
NET STOP /Y NINetworkDiscovery >NUL 2>&1
SC CONFIG NINetworkDiscovery START= DISABLED >NUL 2>&1
NET STOP /Y niLXIDiscovery >NUL 2>&1
SC CONFIG niLXIDiscovery START= DISABLED >NUL 2>&1
NET STOP /Y niDNSResponder >NUL 2>&1
SC CONFIG niDNSResponder START= DISABLED >NUL 2>&1
"C:\Program Files\National Instruments\Shared\mDNS Responder\nimdnsNSPTool.exe" -remove "981DF75B-898E-4c0c-B01C-5F181F817889" >NUL 2>&1
"C:\Program Files(x86)\National Instruments\Shared\mDNS Responder\nimdnsNSPTool.exe" -remove "981DF75B-898E-4c0c-B01C-5F181F817889" >NUL 2>&1
Message 51 of 53
(2,903 Views)
Darn, sorry, typo in service name:
This is tested and working now!
:: STOP AND DISABLE nimDNSResponder Services
NET STOP /Y nimDNSResponder >NUL 2>&1
SC CONFIG nimDNSResponder START= DISABLED >NUL 2>&1
:: REMOVE nimDNSResponder (two instances for 64-bit systems)
IF EXIST "%PROGRAMFILES(X86)%" "C:\Program Files (x86)\National Instruments\Shared\mDNS Responder\nimdnsNSPTool.exe" -remove "981DF75B-898E-4c0c-B01C-5F181F817889"
>NUL 2>&1
Message 52 of 53
(2,860 Views)
I have the same issue.  Putting the following tasks into manual gets around the problem, but I don't want to have to do this cause we run lots of computers, and this is a pain for IT to implement everytime we install the run time.
NI License Server
NI LXI Discovery Service
NI mDNS Responder Service - Stop if running
NI Network Discovery
How do I fix it correctly without having to add the remove registry lines?  I am using 2015 SP1 now, had hoped this would be fixed by NI by this time.  It was happening with labview 2012.  Can I put the remove registry lines in the project somewhere so they automatically occur when the build is made?
Edit: I found the link above on page 5 that shows you how to add the bat file to a build pretty much does it. Still think this shouldn't be necessary to add, but at least it can be done.
Thanks in advance, Andre
Andre
Message 53 of 53
(2,738 Views)
