labview serial number
I have a labview installation that I think has become corrupt. Labview will no longer launch. Is there any way of finding out the labview serial number without launching labview, is it in the ini file or somewhere else. I think this system will require a fresh install to correct the corruption & I want to recover the serial number before uninstalling.
Any help gratefully appreciated.
(6,999 Views)
It is in the registry under Local Machine/Software/National Instruments/LabVIEW
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(6,985 Views)
You should also have a "Certificate of Ownership" which includes the serial number. This certificate is part of the package you should have received when buying LabVIEW.
hope this helps,
Norbert
[EDIT] Note that this certificate is a peace of paper.....
Message Edited by Norbert B on 07-09-2009 04:11 AM
Norbert
Expert: Geometry
(6,974 Views)
Thanks for the help.
(6,958 Views)
You could as well get it from NI by providing your PO ,
incase you are not able to find the certificates from NI`s
LabVIEW Package.
Sundar.
(6,956 Views)
