labview (serial port from usb)
Thanks @Johnsold 4 ur reply
But i want to take data without DAQ Device because i cannot buy this device ,for this
either i should connect serial port externally on Emg circuit and then use A/D convertor .
I m asking u will it then possible 4 me to show on Labview because i am not sure about being compatible of this circuit design with labview
Message 31 of 33
(1,385 Views)
If your time is worth anything, it will cost you more to design, build, and test an A/D converter and a serial port circuit than to buy an inexpensive DAQ device like the USB-6008.
If you are an accomplished analog, mixed signal, and digital circuit designer, then you should be able to build all the circuits you need. In addition to the A/D converter and the serial port, you also need a controller which manages the data format and timing for the whole system.
Since you do not appear to understand what is required, I think your cahnces for success are low.
Lynn
Message 32 of 33
(1,378 Views)
The cheapest solution could be an arduino.
Message 33 of 33
(1,365 Views)
