labview servo (sg90) parameter problem
Hello everyone, i am trying to do pid servo motor control on labview. As far as i am concerned, i need to acquire the transfer function of motor but i don't know the parameters of motor. I could not find from its datasheet. I will use sg90 servo motor on my program. How can i obtain the parameters? If you interest and can help a bit, i am glad.
(4,448 Views)
Talking to the motor vendor might give you some insight, but if you want the transfer function for the motor -- and what it's driving, you will need to measure it.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,418 Views)
 I will try to look through the angle of motor on my program with pid alghoritm. I will use Arduino Uno for this program. An user will set an angle value what wants,then i will try to bring to specific angle.
(4,382 Views)
Hello!OguzAkseki, I need help from you!!
(4,078 Views)
Hi Ahmed803,
As this thread is about a year old I would recommend you create a new thread with a detailed question for the highest chance of receiving help on the forums!
Best of luck.
A. Frank
(4,053 Views)
