labview shared variable
Can any body help me in reading analogue shared variable read in LabVIEW 2009 dynamic event structure. I have tried to read the above tag through Tag Reader VI but i have experienced too much delay in first read for real data i.e. Plant data from PLC. when this particular VI executes it take minutes to display the data. if some needs its code i can provide it. Thanks in advance
Message 1 of 9
(4,001 Views)
Hi SSRaza
Could you upload some code demonstrating the issue?
Peter D
Message 2 of 9
(3,990 Views)
how can i send u these images or the files vi. should i send these to ur email?
Message 3 of 9
(3,971 Views)
When you reply there is a section for attachments underneath the section for entering the body of your post.
If you browse to your VI, it can be uploaded to the forum here.
Peter D
Message 4 of 9
(3,965 Views)
First one is On value Change Event Structure and Second one is Through Read Tag
Message 5 of 9
(3,955 Views)
Hi SSRaza
The code here all seems fine.  Just to clarify, were you having delays using the tag approach, and as such are trying to use the dynamic event structure?  Are you getting any error codes?
There's a good example which writes data to the shared variables and then uses the dynamic event structure to read them back.  It's called "DSC Events Demo.lvproj" and you can get there by searching for DSC in the Example Finder.
Peter D
Message 6 of 9
(3,945 Views)
You might consider reading each tag individually, as per the advice in the DSC Tag API example.  Try out the modification I've attached.
Does that help?
Peter D
Message 7 of 9
(3,941 Views)
will you please send me these in LabVIEW 2009 version as i have LabVIEW 2009
Message 8 of 9
(3,918 Views)
Hi SSRaza
Here it is for LabVIEW 2009
Peter D
Message 9 of 9
(3,902 Views)
