labview signal generator NI MAX Hex 0xBFFF0015
I have a RIGOL signal generator and want to use LABVIEW to control it. When I open NI MAX to debug it, it always reports an error (Hex 0xBFFF0015). Have you encountered such a problem?
(1,335 Views)
You get better help contacting their tech support.
(1,279 Views)
See Error -1073807339 Timeout Expired Before Operation Completed
What command did you send in the NI-VISA Interactive Panel in NI MAX?
You can search in Instrument Driver Network (IDNet) for a library for that instrument.
https://tmesystems.net/
(1,319 Views)
Who knows?  You'll have to supply a much better description of the "troubleshooting" part.  What did you try to send?  Is this instrument SCPI compliant?
Bill
CLD
(Mid-Level minion.)
(1,286 Views)
