labview system exec matlab
Hi, I am trying to implement  a v.i where i call matlab  from labview to run a script using system exec.vi of labview. When i call the script using octave as the .exe to be called it works fine..however with matlab as the .exe it doesn't seem to work properly,,,.i have attached my v.i...please help  me figure what i could be doing wrong..thank you
(3,435 Views)
Hi
have you try to run Matlab without any script?
Is the system exec.vi able to run just Matlab?
Best!!
(3,404 Views)
yes it was just supposed to open matlab..i hadn't tried running it without any script..anyway i have figured it out..i was passing wrong commands to system exec..i used this link to figure it out http://www.mathworks.it/it/help/matlab/ref/matlabunix.html...thanks
(3,376 Views)
