labview to kml
i have a vi  that convert to kml  ,
there is something wrong i want to have the time out of the file  , wich it does only not in the right field it displays as a value
But the kml need some thing specific  format   something like this
 <TimeStamp>
        <when>2007-01-14T21:05:02Z</when>
      </TimeStamp>
and mine data is like this
 <Data name="val">
        <value>17:22:33.751</value>
      </Data>
i have really no in depth know how                         to solve this some one who knows how?
Message 1 of 12
(5,506 Views)
What is "kml"?
Do you mean XML?
Message 2 of 12
(5,496 Views)
see cees10 previous post here
and a quick search in the forum regarding kml leads to this thread
Message 3 of 12
(5,487 Views)
So then it really is XML.  Just Google in all their infinite wisdom decides to corrupt the name of the extension for their own purposes.
Message 4 of 12
(5,484 Views)
The problem is that LabVIEW doesn't make writing XML easy.  Here's an example showing how to use EasyXML (a tookit for LabVIEW from JKI) to write a KML file.
Message 5 of 12
(5,459 Views)
Post the VI and receive more indept help on the problem.
André (CLA, CLED)
Message 6 of 12
(5,446 Views)
here the VI as requested
Message 7 of 12
(5,414 Views)
The values as indicated in the initial post are not written or composed in the posted VI.
André (CLA, CLED)
Message 8 of 12
(5,404 Views)
well andre   this is written from this VI  (exceot the value of course 17:22:33.751 ) becuase this was read out of the file that was selected and the file is a normal text file   with data  and headers that indicate the signal name
 <Data name="val">
      </Data>
Message 9 of 12
(5,400 Views)
In that case please post the kml_llb.llb file instead and a data file. This allows us to reproduce your result and suggest changes.
André (CLA, CLED)
Message 10 of 12
(5,374 Views)
