labview version PXI cDAQ
Hi to all,
i'm starting a new project that include a PXI and a compactDAQ under the PXI. the PXI has to control a motor using the NISoftMotionModule. the PXI data and the cDAQ data will be sinchronized. i will use DQMH framework
i would like to know if there is a labview version that you suggest to use, in order to get an high stability for the development of the source code and final executable app
stability can be:
labview crash reduced...ecc...ecc
how do DQMH works on PXI?
something that i'm ignoring
which version do you suggest?
best regards
(1,996 Views)
(1,960 Views)
