labview version
i bought a new measurment and automation system , and with it i recieved a usb that says : NI System driver set 2022 Q1 , i was wondering will it be ok if the labview version i have is 2022 Q3 ? and if not how can i uninstall labview with all the drivers and add on , and where to find the Q1 verion ,since its not available in the download scroll down window ?
Thank you.
Message 1 of 8
(3,847 Views)
I'm not sure what a "measurement and automation system" consists of, but if it is a bunch of equipment from NI (hardware of various sorts) and it came with a USB Flash Drive that contains 2022 Q1 software, then probably the 2022 Q3 software that is on your system will work just fine.  NI tries (not always successfully) to "upgrade" its software so higher numbered versions should be back-compatible with earlier ones (within a few years).  As LabVIEW 2022 Q3 was fairly recently released, a Flash Drive that was "frozen in manufacturing" a few months ago might well have such an earlier Version number.
Bring up your system, plug in your device, open MAX, and see if the device is present in "Devices and interfaces".  If so, you should be Good to Go.
Bob Schor
Message 2 of 8
(3,782 Views)
It should be fine as there is no change in LabVIEW major version (2022). Moreover, in 2022, drivers are LabVIEW version agnostic.
Santhosh
Soliton Technologies
Message 3 of 8
(3,765 Views)
1. LabVIEW 2022 was not released until Q3.  So it will not be compatible with drivers from Q1 (most of which are actually version 21.X, meaning compatibility with 2021 development systems).
2. Not all drivers have been moved to the "LabVIEW version agnostic".  I noticed many moved to this with the 2022 Q4 software release.  See this for more details: Extending Compatibility Between LabVIEW and NI Drivers with Addon Support.
Now back to the OP's issue...What devices, exactly, are you using here?  NI recently released a bunch of drivers to be usable with LabVIEW 2022 Q3, but it is likely there are versions of the drivers available.
Message 4 of 8
(3,738 Views)
im using NI 9210 , ,NI 9212,NI 9485 and NI 9263, do you think that i should look up for driver updates on NI package manager ?
Message 5 of 8
(3,700 Views)
Hi aasaleh,
These are just modules.
Where do you plug them in? cRIO? cDAQ?
Message 6 of 8
(3,692 Views)
a cDAQ-9178
Message 7 of 8
(3,686 Views)
@aasaleh024 wrote:
a cDAQ-9178
Then you just need the DAQmx driver.  There is a 2022 Q3 and a Q4 version that will work with LabVIEW 2022.
Message 8 of 8
(3,633 Views)
