labview viewer
You probably have several options, depending on the type of license deployed at your location. What version of LabVIEW do you have?
If you have LabVIEW 8.0, check the following link:
http://www.ni.com/license/licensing_options.htm
For example,  "A named-user license is tied to an individual user who can install the software on up to 3 business computers at any given time, in addition to a single home computer. "
Are you at a University? Maybe your campus has an Academic Site license?
http://digital.ni.com/express.nsf/bycode/ex4fjs
In any case, you could also simply install a remote control server on the other computer, then use it remotely. (e.g. http://www.tightvnc.com/ , but there are many others).
Message 11 of 25
(7,487 Views)
This is a follow-up more than a year after the original message, just as an FYI to anyone else doing what I tried to do.
I'm a scientific technical writer (independent consultant) working on a project to document testing some time after the event. The environment is regulated (FDA), relating to medical devices.
Among the support items to be submitted along with the documentation is a LabVIEW .vi file, and as is often the case, I am required to document the file(s) being supplied.
In this case, the test materials and equipment have long since been dismantled or re-assigned and are no longer available. At the time, no-one thought to try to document the .vi other than as rather poor screenshots (familiarity with LabVIEW is moderate among the engineers, but familiarity with documentation requirements and the planning required is low, so no-one thought to try to produce even the HTML version of a report, as was suggested here. And just as an aside, persuading an engineer who is trying to get a job done ASAP that s/he should document in detail what they are doing is a HUGE no-no, as any technical writer will tell you :)).
I went in search of some kind of viewer in the hope that this would enable me to reproduce the contents of the .vi file, and found references here to the LabVIEW Player, now since defunct, which is a great shame. A viewer capable of re-creating (but not necessarily executing) the screen view of the original .vi - similar to the way that Adobe Reader lets someone without Adobe Acrobat view PDFs (and where there are many excellent alternatives to Adobe's Viewer, too) is a must-have, no two ways about it.
I have tried, with the help of an engineer who was not involved in the original testing, to load the .vi into LabVIEW and the results are, predictably, not very useful, since the equipment and materials are not available - lots of big question marks where LabVIEW can't find and/or connect to equipment.
I would suggest that even a .jpg image, embedded in the binary .vi, showing the working image that would have been seen when the .vi was originally created/saved, would be a very helpful addition for people like me. If access to such an image was possible using a simple viewer application, it would resolve documentation problems for those who would otherwise have to learn a lesson the hard way.
Best,
Peter
Message 12 of 25
(7,290 Views)
In this case, there is nothing you could do. The question marks are not missing hardware, but missing software. Specifically, missing functions.
LabVIEW VIs are already far from the most compact form of source code available and adding redundant data to them would only make them bigger. Also, a simple image is not enough to capture a VI, because a VI has some 3D data (structures which have multiple frames which occupy the same space).
Basically, you need to find and use the software modules missing when you open the VI and then the code will look fine when you open it in LV.
___________________
Try to take over the world!
Message 13 of 25
(7,278 Views)
Interesting... Thanks for the feedback.
To the best of my knowledge, we have everything except the previously attached hardware - an exact copy of the folders and contents of the LabVIEW project as it was left on the PC in use at the time and untouched since then. If modules really are missing, that may cause even more problems. Oh, well. Not my problem...
Best,
Peter
Message 14 of 25
(7,266 Views)
If it is the exact same PC, with nothing uninstalled, etc. then there is another option -
LV stores paths to VIs as relative paths. When you open a VI, it tries to open its subVIs assuming they are in the same relative location as they were when the VI was saved. If it can not find them, it starts searching in a list of predefined locations. If it still can not find them, it displays one dialog for each missing VI asking you to select the relevant VIs.
If the project was moved to another location on the HD, then some of these links can be broken and you either need to have the project (and the VIs it's looking for) in the exact same spot as before or find the VIs manually.
Another option is that a newer version of LV was installed which does not have everything installed or that a new version of a hardware driver was installed which removed the old version.
___________________
Message 15 of 25
(7,260 Views)
To the best of my knowledge (limited, because I'm going by the assurances of others), the PC has not been changed in the interim, and the project folder is as it was at the time of testing, with all required modules contained in subfolders.
As far as I know, the only aspect that has changed is that the test equipment in use at the time, and the materials under test, are not present. Other projects have been installed on the same machine in the interim but no changes have been made to the project in question.
If in the future I find that is not the case, I'll post details (if possible) or at least post that changes were made after all.
I'm hampered by a lack of knowledge of LabVIEW. I had thought that we could have used LabVNC to view the .vi, but the restrictions on access to the PC (placed inside a restricted access lab within a restricted access building) almost certainly prevent us from installing any server app on the PC that would allow anyone outside the lab to access a .vi. Regulated environment rules, I guess.
I'll keep my options open if I can, but it looks as though we may have to submit documentation based on the poor screenshots and a description of the situation as we found it, in as much detail as we can verify. That happens all too often in regulated environments IME, sadly.
But thanks for your attempts to help - all assistance gratefully received, as always.
Best,
Peter
Message 16 of 25
(7,250 Views)
If you dubble click a question mask vi (the missing vi), you get a pop up with it's name. This way, at least you can tell something about what the program is supposed to do. That is, if they gave the sub vi usefull names (probably not)...
Perhaps the program uses a toolkit or hardware module. If a newer version of LabVIEW is installed, that toolkit or hardware module might not be installed. If you post some of the names of the missing VI's, someone here can tell you if that is the case. Installing the hardware support or toolkit could fix your problem.
Wiebe.
Message 17 of 25
(7,209 Views)
Or easier, enable context help (ctrl+h) and hover over the various missing subVIs. You'll get their name in the context help window. 🙂
Message 18 of 25
(7,193 Views)
Yes, that is easier...
Message 19 of 25
(7,185 Views)
Alas, I only had a narrow window of access - restricted area in a regulated environment - and I doubt I'd be allowed to publish any details, anyway. The documentation had to go ahead without the information and is now out of my hands.
But I appreciate all attempts to help - and hopefully the engineers concerned will know what pitfalls to avoid next time...
Best,
Peter
Message 20 of 25
(7,176 Views)
