labview vs matlab
Hi, Maybe the title for the theme is not adequate, sooty for that.
I have recently bought the modulation toolkit ( i am working on a project of modulation and demodulation). But also simulink has tools to work that sort of project (I have recently been told). So my question is which of the 2 would have been better for my project.
Well. my project consists on the modulation and demodulation of signal that i acquire using the pci 6221.
What advantages and disadvantages do i have using modulation toolkit instead of simulink in a Telecommunications project?
Greetings
(3,169 Views)
Hello a92626113,
I don't have much experience with the Simulink modulation tools, so I won't be able to do a comparison of the two.  An obvious difference is that the NI modulation toolkit is built in LabVIEW.  So if you have an application that has already been written in LabVIEW and/or if you have developers who have a LabVIEW background, the learning curve for the toolkit should be minimal.  But regarding the NI Modulation Toolkit, I can direct you to the datasheet which goes into some detail on the VIs included in the toolkit.
Hope that helps.
Wendy L
Wendy L
LabWindows/CVI Developer Newsletter
(3,129 Views)
