labview window to top
I have a Labview executable that should display its window on top on specific events. Unfortunately the window stays hidden behind other applications such as the browser (even when modal). I could set it to floating, but I don't want to do that for the main window. Furthermore, floating windows do not get activated.
Who has an elegant solution for this?
(3,668 Views)
Here's a discussion on ^this subject.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,661 Views)
Thanks for the tip. I did find that solution, too. Unfortunately, The provided VI's don't do the trick oftentimes!
I think I will give autoit a try, too. I've used autoit for other automation projects, but not yet in combination with labview.
I am also condidering the following: minimising all other windows first!
(3,590 Views)
I created a tiny executable with Autoit.
I run the executable with exec.vi and pass the name of the application as a flag to ensure it will always activate the right window.
It works. Elegant? Nah..
(3,563 Views)
