labview with plc(siemens)
Hallo,
i want to know, if it is possible to write a program with labview; and send it with TCP/IP Connection to the PLC.
i'm using Siemens s7.
for example;
u m 1.0
u m 1.1
=a 1.0
i want to write this code from labview to plc. i dont want to use simatic;
or i have the code (program) and i want to write more network in plc.
Hakan
(3,537 Views)
You can write a program in LabVIEW, that communicates with a PLC via Datasocket. Datasocket can communicate with the OPC-Server of the PLC. It is not possible to download a LabVIEW VI to a PLC, so that the VI runs on the PLC. The VI will run on a computer, that communicates with the I/Os of the PLC.
You can find an example attached to this message.
As an alternative, you could use a Fieldpoint system instead of your PLC. You can DIRECTLY download VIs to a Fieldpointsystem. Here you can find morte information about fieldpoint:
(3,523 Views)
thank you very much for your reply.
but i couldn't open VI, because i use Labview 7.1
is it possible that you change VI for Labview 7.1?
(3,516 Views)
Here you go 😉
(3,510 Views)
