labview
Hi, i have to do a project that takes a 2D image (for example of a mauntain) and makes it 3D as a hightmap. Then i need to take from that highmap two random points and get the difference between them as a lenght. There are two main problems. First have less then basic knowlage in labview and secound - the project must be done till this friday (29.09.2017) If some one has done a project like that or at least has some clue, how to do it... that wouId be great. I have fount a forum post about, how to make a 2D image into a 3D, but no idea, how to modify it so, that i mesure two random points.
(3,167 Views)
This sounds like a homework assignment for a class.  As a general rule we don't do your homework for you, and if you want assistance you need to at least have started on something.
Have you started a VI yet?  Can you post it so we can see where you're stuck?
(3,164 Views)
That's the third thread with roughly the same question that you started. Do you really think that bumping will motivate people to answer you?
https://forums.ni.com/t5/LabVIEW/How-can-from-2D-image-I-make-a-3D-in-labview/m-p/3673752
https://forums.ni.com/t5/LabVIEW/project/m-p/3694413
Jens
Kudos are welcome...
(3,132 Views)
