labview
Can someone help me find this in the tool pallet please? I'm new to labview and struggling thank you
(1,684 Views)
The correct case is LabVIEW
That is a vi not a tool.  The tools pallet allows you to switch from wiring, text, selection, and other tools the mouse uses.
The vi would be on the Functions pallet.  But, it is not a vi that ships with LabVIEW (someone else made it)  you can right-click it and show the vi name or show the vi hierarchy window and show the vi full paths from the menu.
(1,674 Views)
Are you trying to recreate a VI from a picture found somewhere? This is definitely not a "tool", "vi", "function", etc. that ships with LabVIEW (NI has professional style guidelines, and this is not it!).
If you have this subVI on a diagram (assuming it actually is a subVI!),
  • just hover over it with the context help open and see what it says.
  • double-click it to see what's inside. Follow the wire. read diagram comments, etc.
If you just have a picture, tell us where you found this picture. Give a link or reference! If it is a scientific paper, have you tried to contact the authors?
(1,666 Views)
Right click it and show it's label (and tell us).
Even if the VI is missing (you can't open it) a name would help...
(1,635 Views)
