labview6.1 hangs on windows 98 when using adobe acrobat control for activex to open pdf file
I downloaded the attached vi from this forum and it works perfectly in windows XP with the same version of labview(6.1) and adobe acrobat reader (6.0). However, it hangs immediately when i am just trying to open the vi on windows 98....
I have also experimented with the MS browser activex control(activex container + object), it works on both windows XP and 98 for opening html files and on XP, it can open a link that leads to an PDF file display properly in the container window but it fails again in 98.
Please help ...... thanks
(3,407 Views)
I can't try it on Win98 but have you tried the Open Acrobat Manual VI that ships with LabVIEW? It's in LabVIEW 6.1\help\_browser.llb.
(3,399 Views)
Thanks Dennis. That one works on both win 98 and XP but it isn't what i am looking for.
I need the pdf to be loaded in a labview container so that i have the flexibility to load/print any PDF(s) as i wish.
(3,380 Views)
It sound like you have a problem with the Acrobat ActiveX object in you 98 PC. Can you open a PDF document in IE? If not, you may wish to try and uninstall\reinstall Acrobat or try to select the Acrobat object directly from the list of objects. If not, maybe a different version of Acrobat will work.
___________________
Try to take over the world!
(3,376 Views)
Yes, i can open pdf file in IE......and i have tried to add the object directly from the list and the whole pc just hangs....
What version of acrobat would you suggest?
(3,364 Views)
@mengyi wrote:
... What version of acrobat would you suggest?
The VI you posted worked without a problem on my Win98 machine with AcrobatReader v5.0.5.
Fading out. " ... J. Arthur Rank on gong."
(3,356 Views)
yes, that solves the problem......
Thanks all
(3,339 Views)
