lading labview application to the server to be viewed by users
Hi.....
We have labview applications used by our clients.
I would like to know is there any way to load the applications in our server and the users at the client's side can view the application.
Thanks in advance
(3,095 Views)
Look at the Web Publishing Tools on the Tools menu.
(3,093 Views)
Thanks for the reply.I tried with web publishing tool,in the following manner.
Opened the vi to be published to the web then selected tools->options->Web server configuration and checked enable web server.And set HTTP Port and Timeout as default.
After clicking ok,i selected webpublishing tools from tools menu.I tried in all the 3 viewing modes.But i was not able to preview in browser.
When i was trying to do so i was getting the following error.
Error 7 occurred at an unidentified location
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux.
NI-488:  Non-existent board.
I tried the same method in another PC.There i was able to preview,but it was giving the page for "page can not be displayed".
I tried to copy and paste the address in internet explorer.But again getting page can not be displayed.
How do i fix this?Why it fails to display the vi and shows page can not be displayed.
Thanks in advance
(3,072 Views)
Have you checked the PC's firewall settings to make sure it is allowing access on port 80?
(3,061 Views)
Hey User_1,
What version of LabVIEW are you using?
Read through the below links;
[link removed]
Hopefully these help.
Aashish M
CEO
TransferFi
www.transferfi.com
(3,032 Views)
