lakeshore temperature controller
Hello Forum,
                   I downloaded the drivers for the Lakeshore 331 temperature controller and am trying to implement it, without success. (I'm getting a time out error at my VISA Read function). So, I used my Basic Serial Write and Read.vi to test whether the cables and ports are working properly by simply writing to the controller '*IDN?\r\n'. Instead of getting back the expected 'LSCI, MODEL 332S, 332603, 112002', I get the garbeled response shown in the file attached. The read message contains exactly the right number of bits, so I know that my computer is able to communicate with the controller. But why can it not reply in an intelligible language? Is this due to an error in my computer or labview settings or with the controller? Furthermore, is this why I cannot operate the driver.
Any help would be greatly appreciated,
                                                        L
(4,419 Views)
Accepted by topic author luiz_iniciante
This generally happens when the settings for your serial port and those on the device don't match. Make sure that you are using the same settings (BAUD rate, stop bits, parity, etc.) on both sides of the connection.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(4,414 Views)
Thanks Mark, it worked.
(4,393 Views)
Hi, I'm even not able to get the connection between my PC and the LakeShore 331? Using the same "Basic Serial Write and Read.vi" to test whether the cables and ports are working properly. Sending *IDN?\r\n , I don't get anything? The vi goes at the end and doesn't read anything. That it's?
Any suggestion?
By the way, what is the type of the cable you use? Standard RS322 DB9 connection or any special one?
Thanks.. 😉
Vids
(4,220 Views)
