large amount of bound variables error handling
back again.
Is there some good procedure if I got about 100 variables from a controller and I want to do error handling? Do I have to wire every variable with error in/out, in series? Wouldn't this take 100 operations/steps, because it has to check every one?
I.e. most likely read error from PLC.
Lots of them are in lots of 8. Data from 8 motors, voltage 1-8, RPM 1-8 and so on. I will make them arrays to pass them on. Maybe just check every array?
Thanks for your replies.
(3,449 Views)
I suppose it depends on whether or not you care if those variables are throwing errors, if you want to know, there aren't a whole lot of other ways to find out.  Am I to assume that by variables you mean "Shared Variables"?  You don't have to wire them all sequentially just so you know as well, you could wire them in parallel, and use a "Merge Errors" vi to get the errors back to a single wire.
(3,407 Views)
pretty much 100+ shared variables from the I/O server, coming from a PLC via Modbus. So most likely either I get all or none. And some BS reading, when sensors are not connected, but that is not an error as such. I think connection state should do. And the variables, just give them a timeout.
(3,395 Views)
Yeah, I've dealt with that many variables before.  Generally speaking you're right, that's about all they'll tell you if they do have an error at all.  There are a few more minor ones that can come up, but they probably won't.  Take a look at the list here for the top ones:
http://digital.ni.com/public.nsf/allkb/B9366256C53D95CA8625725A007C028
(3,379 Views)
most likely there will be something like cannot connect to SQL later on and cannot open VISA connection. This should not affect the variables
(3,373 Views)
