large digit display
Is there anyway to have a digital numeric display that is much bigger than the number boxes availiable?
Message 1 of 14
(5,181 Views)
The size of the number boxes depends on the size of the font. Select the text in the box and use the font dialog. Choose the font you want e.g. Courier New and set the size. You are not restricted to the select box for setting the size, type the size in.
If you use Courier New with a size of 256pt you get a number box with the hight of 264 pixel.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 2 of 14
(5,181 Views)
Select the Digital Num display and
Click the following kb buttons
Increase
[CTRL][+=]
Reduce
[CTRL][_-]
Cheers
ian
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 3 of 14
(5,181 Views)
showhow...
regards
Ian F
依恩与LabVIEW
Message 4 of 14
(5,181 Views)
Thanks....that's exactly what I was talking about.
Message 5 of 14
(5,181 Views)
"Richie Y." wrote in message news:<506500000008000000105D0000-1031838699000@exchange.ni.com>...
Richie,
In many cases it's easier to make the large numeric displays using
picture controls. You make a control number feed into a VI, and in
the output picture indicator you get the numbers.
Message 6 of 14
(5,181 Views)
hi Richie
Your rating to my answer would be very much appreciated.
Many thanks 🙂
Ian F
依恩与LabVIEW
Message 7 of 14
(5,181 Views)
You have been rated...
sorry, I'm new here
Message 8 of 14
(5,181 Views)
I'm not understanding your answer...I guess I haven't used picture controls. If you could explain in a little more detail that would be great.
Message 9 of 14
(5,181 Views)
very nice of you 🙂 cheers and have fun with LabVIEW.
It's COOL, believe me 🙂
Ian F
依恩与LabVIEW
Message 10 of 14
(5,181 Views)
