laser beam steering
I want to perform laser beam x,y steering using labview and NI Hardware.
The beam steering has to be done as per a user input image file.
The picture is inputted in to LABVIEW.
Beam steering is done by 2  galvanometer scanning mirrors, one scans in x and another in y.
The NI hardware generates the electrical signals as per the input image file, and these signals  drive the  "galvanometer scanning mirrors".
I would be grateful if you could please get me started on how to get started on  it?
I am designing this set up  from scratch and need some familiarity with  what type of NI hardware can do something like this?
thanks a lot!
nzb
(2,885 Views)
nzb,
This is a quite general question so I will answer it with a general answer.  if you open LabVIEW, go to Help -> Find Examples.  There is tons of example code in there and I am sure that one of them will do something that you may be looking for and will help you get to grips with your project.
Robert Ward
Applications Engineer, NI
(2,875 Views)
As to hardware selection, you have to determine a bunch of things, at your end, to allow you to pick the hardware, for example:
1- what are the drive requirements (voltage and current) of the galvonometers?
2- what frequency are the drive signals (determining how fast the mirrors have to traverse, both in a "scan" and if appropriate a "retrace" will be a starting point.
From that you should have a starting point to determine what the hardware requirements may be, and can then start looking at the hardware.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,867 Views)
