laser sensor Labview program
I tried to retrieve a data from a Optex laser sensor, CD22-35-RS485-M12.
I used a Rs-485 to USB converter link to my laptop.
It shows error when i run the program.
Attached a Labview program, error massage file, laser sensor user manual and cable connection for your reference.
Please use my Labview project file for amendment.
Thank you very much.
(2,411 Views)
Hi Jeffrey,
  • Did you verify the COM port settings? The error message says one or more of those settings isn't supported by your COM port (aka that USB-to-RS485 converter)…
  • Did you try to use different settings on your sensor device?
  • The strings sent to your device seem wrong to me: your device expects bytes (aka U8 datatype) instead of strings containing 2 ASCII chars for values like "02h"!
  • You should never use BytesAtPort! Instead you should read that 6 bytes of the device response! (Or set ETX as TermChar and read one more (BCC) byte…)
(2,395 Views)
The stop bit value is invalid: the right value is not 1 but 10.
I suggest to delete your constant and the conversion function, right-click the input terminal of the Configure vi and select Create --> Costant.
The same you can do with all other vi inputs. Conversion functions are not necessary.
All other suggestions from GerdW remain valid.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,386 Views)
