last row in excel
You could have a look at the VI I've attached, specifically the middle part containing the "Range:Find" method.
Caveats:
The attached VI works for me, but is largely a cut and paste together of bits I've found on the web.
I know little about ActiveX.
I know less about Excel.
So, you take your chances. That said, it may be worth a try.  If it doesn't do what you want, is the answer a different operator to the "*" used. I don't know. Hope it may be of some use anyway.
Regards.
Message 11 of 12
(1,199 Views)
Toolkit does open existing excel files and able to write into them also.
Ii tried by adding and clearing the data. I could find the cell properly....it does not include the cells that are not used any more
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
Message 12 of 12
(1,173 Views)
