latching trouble
Does anyone of you guys know how to resolve the following. I've got a while loop consisting of a case structure with a latched button attached to it. When a certain event happens in a different part of the program I want to trigger the case structure once, i.e. setting the button on and off. Is there a way how to do this with the 'mechanical action' of the button swithed to latch?
Cheerio, Georg
(2,839 Views)
Latch action is not compatible with local variables, but there is an easy way around it.
Simply use a "switch action" and do the latch programmatically using another local variable (see attached example code image).
(2,839 Views)
Thanks, that helped me out!
(2,839 Views)
