launch DS in compact fieldpoint
I have two simple VIs that uses datasocket, Write DS.vi and Read DS.vi.
I'm using the function  Launch DS Server if Local URL.
In my computer works ok, but when I execute my VI in a compact FIeldPoint (cFP-2020), DS server don't works. It appears the messsage "Launching the DataSocket Server is currently not supported on non-windows platforms. Please try connecting to a DataSocket Server running on windows." (application TargetOS is FALSE).
Are there any solution?
Thank you.
Vicen
WinXP / LV 7.1
(5,247 Views)
why don't you launch DS Server from the windows side instead of RT?
DS Server only can run in a Windows operating system. If you are using a RT system and are going to use DS Server, you will probably have a Windows VI. Use this VI to launch the DS Server.
I hope this helps.
Regards
crisR
(5,222 Views)
Look for "Publish.vi" in the FP palettes.
That VI and its associates will deploy a DS Server and allow you to read and write from same on a FP unit.
Ben
(5,220 Views)
Ben,
I think Publish.vi is not based in DS Server but logos. In fact, if you use Publish.vi in a FP RT unit to publish items, when you subscribe to those items from a host PC, you use logos protocol in the DS functions to connect to.
Regards
crisR
(5,178 Views)
