launch bar
It is easy to hide or to show the bar of fast launch.
But how can we obtain the list of the elements in this bar ?
Thank you for your help
Message 1 of 12
(4,580 Views)
Hi Jacouille
Can you explain little more about which bar you are talking about?
Message 2 of 12
(4,557 Views)
Message 3 of 12
(4,538 Views)
Hi Jacouille,
you should ask that question in the MSDN forum as it clearly is a WINDOWS feature…
Message 4 of 12
(4,525 Views)
Hi
which MSDN forum ?
Message 5 of 12
(4,520 Views)
this MSDN
Message 6 of 12
(4,507 Views)
It I knew that
I think of a MSDN within the labview community
Message 7 of 12
(4,490 Views)
Why should there be a Windows support forum inside the LabVIEW support forum?
You already have the MSDN and you will find all information about Windows over there…
Message 8 of 12
(4,487 Views)
That is also called the taskbar,  not the launch bar.
Message 9 of 12
(4,466 Views)
For those that stumble into this thread, this feature in Windows 7 is for when you pin a program to the taskbar.  In older versions of Windows this was called Quick Launch, not the Launch Bar.  People still call it Quick Launch but really that is something different which can be enabled as mentioned here:
http://www.howtogeek.com/howto/windows-7/add-the-quick-launch-bar-to-the-taskbar-in-windows-7/
Message 10 of 12
(4,461 Views)
