launch measurement & automation explorer from labview
Hello: I'd like to know if I can launch the measurement and automation explorer MAX  from LabVIEW
(2,616 Views)
You can use the system execute function to do it. On my system the path to the MAX executable is:
"C:\Program Files\National Instruments\MAX\NIMax.exe"
I just put that into the command line to be executed (including the quotation marks) and MAX launched right up.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,613 Views)
