laview 6 to 9 data types
i meant its writing a voltage value to each of the analog output channels, and many votage values will be used..
Message 31 of 37
(785 Views)
i understand the VI under the examples you asked me to look at which is to work for, how to output a single Voltage Update (Sample) to  an Analog Output Channel. Im looking to ouput voltage to multiple analog output channels (would my attached code from before work for this?)
thanks
Message 32 of 37
(785 Views)
Hi lakersrl,
I'm still a little unsure of what it is that you need to do. If you need to write a single analog output value to multiple channels, then the example Gen Voltage Update.vi will do exactly what you want. It is located in Hardware Input and Output » DAQmx » Analog Generation » Voltage. All you should have to do is change the physical channels to include the channels you want.
Message 33 of 37
(763 Views)
 I was a little confused as I was told to us "Cont Gen Voltage Wfm-Int Clk-Dig Start.vi."? in an earlier posting on the third page.Im looking to replace the AO write one update vi, basically, which writes a single voltage value to each of the specified analog output channels. This sounds like as you said in the previous post, the vi you mentioned would work.
Message 34 of 37
(754 Views)
the description of the Gen voltage update vi says" output a single voltage value to an Analog Output channel"..but as you stated works for multiple output channels? was confusing from description, makes me think saved to only one output channel.
Message 35 of 37
(752 Views)
I believe I would just change the DAQmx write VI to Nchannel, 1 sample, rather than 1channel, 1sample?
Message 36 of 37
(749 Views)
Hi lakersl,
That is correct. If you change it to N channels, 1 sample, you will write one sample at a time for multiple channels.
Message 37 of 37
(723 Views)
