leave visa session open
Which is the better practice?
start program
-----open visa session
----------do stuff
-----close visa session
end program
OR
start program
-----REPEAT
----------do stuff
----------open visa session
---------------do stuff
----------close visa session
----------do stuff
-----END REPEAT
end program
(3,995 Views)
Kind of hard to compare because your first example doesn't have any REPEAT element to it.  So a program with a loop to one without is comparing apples to oranges.
In general, it is better to open a VISA session outside of a loop, do stuff in a loop, close the session outside of a loop.  Particularly, if the loop has a pretty quick iteration rate.
Now if the program was looping, but the VISA stuff was infrequent, such as querying an instrument for data once an hour, I would be inclined to do the VISA open and close inside the loop as well.
(3,970 Views)
What I'm doing is setting up a power supply. My question is, is it better to open a session at the beginning of a program and then use the reference that I create to do things to the power supply throughout the life of the program, or is it better to open a session each time I need to communicate with the power supply and then close as soon as I'm done. In this case, I will only reference the power supply occasionally and the time between calls will be at least several seconds.
(3,960 Views)
For accessing every few seconds, I would open once at the beginning of the program and close at the end.
(3,954 Views)
Accepted by topic author oyester
And remember that you do not have to do either. With NI-VISA, the Open has been optional for quite a few years. A session will be automatically created when you use any VISA function. You can also set it so that VISA is automatically closed. This is settable from Tools>Option>Environment.
That being said, the open and close are probably nice from a compatability issue. I do not know if other company's implementation of VISA work the same.
(3,950 Views)
Usually when I say open, I'm thinking of the VISA config VI where you set baud rate, termination character, parity, ...
(3,941 Views)
