lecroy 936x
Hi, I've tried the lecroy 936x driver with labview 2009, but there are many corrupted icons on instrument panel.
It is possible to correct? Obviusly there are all the functions, but the panel has corrupted links.
(3,713 Views)
You will need to provide more information. What instrument driver did you download? Please provide the link. Also, please describe better what you mean by "corrupted", and what instrument panel you are referring to.
If you can, please provide a screenshot. If you do, DO NOT POST BITMAPS, and DO NOT RENAME BITMAPS BY CHANGING THE EXTENSION. Sorry for shouting, but people constantly do that. Save the screenshot as a PNG.
(3,697 Views)
I downloaded the driver (lecroy 9361) here:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E94E9659CE034080020E748...
When I open the instrument panel, some link are broken (see clip 1), but they are correctly visible, if I open the Tree.vi (see clip 2)
Message Edited by andrea1984 on 03-16-2010 03:37 PM
(3,679 Views)
That's the palette and not an instrument panel.
I am able to duplicate the problem. Something may have corrupted the mnu file. You can fix it yourself by going to Tools>Advanced>Edit Palette View, selecting the palette, and then selecting 'Insert VI' and browse to the VIs in the lcds0b.llb, etc.
(3,670 Views)
Thanks for the answer, and sorry for my bad english.
(3,657 Views)
Here is the updated driver, the download page for the driver will be updated shortly.
(3,632 Views)
