led management
If you have an idea of the ultimate size of the array you can create a case statement that has an initialization case that only executes once to init your array. There are usually many ways to get around almost everything in LabVIEW, although with each new version there is less "getting around" and more just doing it!
P.M.
Putnam
Certified LabVIEW Developer
LabVIEW Champion
Message 11 of 13
(567 Views)
Here is the 7.0 version of my vi, for what it is worth.  It shows how to use a queue to write to the LED array, and how to read the queue to update the display.
- tbob
Inventor of the WORM Global
Message 12 of 13
(552 Views)
Here is an example of how to initialize or not initialize a shift register.
- tbob
Message 13 of 13
(544 Views)
