led up down joystick controlled sequence
Hi all,
I am currently working on a Vi for a class project. I am using a joystick to interface with the Vi. It is basically a simulation of a vehicle with a speedo and rpm gauge that needs to shift up through the gears which are indicated by the LED's with one button and downshift with a different button. As the upshift button is pressed it turns on led and keeps it on. The I would like it to turn off led one and turn on led two when pressed again up to 5. The opposite for downshifting with a seperate button. I have gotten as far as to be able to latch in one led. I have made a small vi for just the led sequence part of it to post. It will however run in the while loop with all the other code once i have figured this out.
I would greatly appreciate any guidance or tips anyone has. Thanks in advance.
Running labview 8.6 and winxp
(3,513 Views)
I'm still hoping that there is a way to do it with just one button. In the meantime I have been working with using a different button for each led and latching it in even after the button reads false.
(3,503 Views)
Instead of working with complicated boolean logic, store your current gear in a shift register as a number.  If the up button is pressed, it increments the value.  If the down button is pressed, it decrements the value.
Now turn your booleans into a boolean array.  Use the value of the shift register to determine which index value of the boolean array to turn on (and all the others would be off.)
(3,500 Views)
Thank You very much! That sounds like a much easier way to go appraoch this.
(3,495 Views)
