legend placement in Excel
I'm trying to control the placement of a chart legend in Excel from Labview using active X. The VBA lines I need to perform in Labview are as follows:
ActiveChart.Legend.Select
Selection.Position = xlBottom
The problem I'm having is that I can't find an automation refnum for Selection. I have tried searching the Microsoft Excel Objects library but it does not seem to be there. I have attached a screen shot of the code. I am relatively new to active X so any help appreciated.
LMS17
(3,311 Views)
Accepted by topic author lms17
Here is what you need yo do. Look at the gif
Tim
GHSP
(3,287 Views)
perfect...thank you.
(3,284 Views)
