legend text length < 30
I am trying to set my legend names to a string longer then 29 charters but can not.  If I try to set it to a string larger then 29 I get a Runtime error that the attribute value passed is not a valid value but do not get the error if the string is 29 charters or less.  I have set the ATTR_LEGEND_AUTO_SIZE to 1 and manualy set the legend to a larger size but my text length max still is on 29.  Is there a way to set the Max Text length in the legend to something larger?
(3,110 Views)
Doesn't that property determine how many names are listed in the legend?
I can get more than that when I tried a chart in LV 8.6.
Plase post an example that demonstrates this issue.
Just trying to help,
Ben
(3,105 Views)
I'm using labwindows 7.1 and I had miscounted it is 30 charters or less that I can use.
(3,097 Views)
OK now I see why I am confused!
Try re-posting this question the the Labwindows forum. This forum is for LabVIEW.
Ben
(3,091 Views)
This thread was moved to the LabWindows/CVI forum: legend length < 30.
Mark E.
(3,064 Views)
