levenberg marquardt
Whenever you get an error code, you can go to "menu...help...explain error..." and paste the number. (see image)
I don't really know what "wrong letter" means, but I would guess you have a syntax error somewhere.
It is impossible to guess without seeing the code. What is your model formula?
Message Edited by altenbach on 01-27-2009 01:11 AM
Message 11 of 15
(1,088 Views)
error solved. As you said, it was a syntax error in the model.
I think it is now working well.
Thanks a lo lot
jm
Message 12 of 15
(1,079 Views)
And the fit is now a little bit strange. Instead of pain a continuous cuadratic line (like the model)
it paints some traces, creating a discontinuous curve.
Do you know why?
Thx
Message 13 of 15
(1,077 Views)
jmhf wrote:
Do you know why?
No, not without seeing the VI! 😉
There could be many reasons. For example what you currently show in the picture should not even work, because you only give starting values for a, but not for b and c.
In any case, if you want to fit to e.g. variable order polynominals, you definitely don't need levenberg-marquardt, there are much better ways.
Message 14 of 15
(1,056 Views)
That´s right!
The problem was solved. It came from a bad function definition.
Thanks for everything
jm
Message 15 of 15
(1,034 Views)
