libguide40.dll not valid
When starting LabView 8.5.1 I get the message that Progam Files\National Instruments\Shared\MKL\MKL70\libguide40.dll is not a valid Windows image. Please check against your installation diskette.
LV just shuts down after this message appears.
Am I correct in assuming it wants the LabView installation CD? Do I need to reinstall Labview or is there a fix available on-line?.
Only reason that I ask is that my install disk is in another location that I can not access today. I was hoping I could work on my application over the wekend.
(3,287 Views)
Try the attached file.
You need to unzip it at first, then copy libguide40.dll to  Progam Files\National Instruments\Shared\MKL\MKL70\
(3,264 Views)
