library not found or failed to load
hi all,
 I'm a competely freshman about LabView. Here's my trouble:
I got a .vi file from my workmates but I could  not run it.
The problem is "This vi's owning library is missing". According to the solution on the Internet, I selected the file and disconnected it from the library.
Then comes the next problem. " Library not found or failed to load". And I have no idea how to solve the problem now.
Should I connect it to some library? Or should I do something else?
My version is LabView2015,  and I only got  a .vi file and cannot get in touch with the guy who worked on it.
Thank you a lot. And please let me know if further info is needed.
(4,611 Views)
Accepted by topic author taoyao
hi
   the library should be included in the project with the vi. if u just have a vi then create a project and include the library. It will be useful if u could attach the vi here.
regards
senthil
(4,580 Views)
Problem solved.
The key point is that the .vi uses a .dll document and the latter is not provided. After adding the .dll document it works( though there are still some other problems). Thank you a lot.
(4,552 Views)
