library sub vi's
I need some sub vi's- Ai aquire waveform.vi,Ai group config.vi,Ai hardware config.vi,Ai buffer config.vi,Ai clock config.vi,Ai single scan.vi
(2,985 Views)
All of these should be present in your LV installation. If these are absent from your installation then I suggest that you reinstall LV so that these vi's will be installed.
(2,985 Views)
These sub-vis are part of the NI-DAQ driver install. Either you have not yet installed NI-DAQ or they have been deleted.
You can download the currnet NI-DAQ here for all OS's.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,985 Views)
Ed,
Thanks for correcting me. Since I install LV and NI-DAQ at the same time I tend to think of them as a single install.
John
(2,985 Views)
