license problem
Hi all,
I have a problem today - I use a multiuse license for LabView, I wanted to install LV on another PC but the installer tells me that my license is not a proper LabView license. Do you have the same problem?
regards,
Marcin
(3,509 Views)
Hi Marcin,
The best course of action would be to get in touch with your local branch.  They can check if your license is valid - and if so generate you an activation key.
Peter D
(3,503 Views)
License is valid, it was renewed few months ago. Nevertheless I will contact local support.
regards,
Marcin
(3,500 Views)
Accepted by topic author bikekowal
As I supposed, it was a problem with NI serwers - today everything works fine.
regards,
Marcin
(3,475 Views)
Glad to hear it Smiley Happy
Peter D
(3,472 Views)
