limitation for DAQmx System Property Node
hai guys, Would like to know if there is any limitation for DAQmx System Property Node to check all the available device name. When i use this function to check all the available hardware in my chassis only certain item can be detected. When i check in measurement and automation all the devices are there and pass the self test examples of device that cannot be detected PXI-5610 and PXI-5441. on the same chassis i have PXI-6229 and PXI 4461 that can be detected. hope some 1 can assist me to solve the prob. thanks regards kokula
(3,636 Views)
They cannot detect cuz they're not DAQmx devices.
For modular instrument, try attached file.
(3,615 Views)
Also there is the System Configuration Toolkit. I just downloaded it myself and don't know all its capabitlities.
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,600 Views)
