Labtracer is a program by Keithley and has nothing to do with LabVIEW. I believe all it requires is a GPIB board from either Keithley or NI. If you want to use LabVIEW, then you would start with a LabVIEW driver. Unfortunately, the only driver from NI is for version 8.0 or higher. I think Keithley has either a LabVIEW or IVI driver that you can use with LabVIEW. I have seen example programs on Keithley's web site that you may be able to use as is or modify. Questions on wiring up the Keithley should be directed to Keithely. That sort of thing has nothing to do with LabVIEW either.
