limited sampling rate
I've got a VI that reads in analog inputs. The DAQ device I'm using is a PCI 6229. I believe that the max. sampling rate of this device is 250kS/s. So, if I were were to take inputs from 16 channels I thought I could enter a sampling rate of 15kS/s (since 250/16 > 15) . However, when I look at my output data, I can find that the sampling rate was actually 14925 S/s not 15000 S/s which I entered.
When I enter a sampling rate of, say, 14kS/s the data shows that it's actually 14kS/s. So I'm wondering whether the maximum limit of my sampling rate is around 14.9kS/s and not 15kS/s.
Cheers.
(3,293 Views)
To be able to help you I’d like to know if you have some error messages? Have you tried a sample rate of 250kS/s on 1 channel? Do you use your 16 input in referenced or differential?
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(3,282 Views)
It didn't produce any error messages when I ran it with 16 input channels and 15kS/s sampling rate (all my input channels were at RSE). I'm just confused as to why the sampling rate on the output file is shown to be 14.9kS/s. I just ran it with 1 channel and 250kS/s sampling rate and the output file did show that the sampling rate was in fact 250kS/s. I've attached my VI for you to have a look.
Probably different to my original question; I've used an example shipped with NI for some analog output, and I'm not sure what a particular function of it used for. I've attached a picture of it here as well (the part which I don't understand circled).
(3,276 Views)
Many multiplexed devices need to allow for settling time for the mux and the amplifier in addition to the sampling rate divided by the number of channels. I did not look up the specifications on your device, but I suspect that this may be the issue.
The time per sample at the nominal rate is 1/(250000/16) = 64 us. The period at the actual rate of 14925 samples/second = 67 us. Three microseconds for switching and settling is not unreasonable.
Lynn
(3,270 Views)
I’m ok with johnsold for the nominal rate but normally the sample rate (here 250kS/s) consider the switching time. This is why I’m not sure about johnsold explanation. I will look for to know why you have just 14925S/s using 16 channels and not the 15625S/s.
Moreover, the cluster entry is the cluster that has the elements that you want to replace. At least one element of the cluster of entry must have a label that it is bound. You should always be wired terminal cluster of entry. I can’t say more about it because I don’t have all the VI.
    Benjamin R.
(3,262 Views)
