i m trying to make limited version of test stand .
i already bulid a project for NIC testing.
i want to generelized this in which following things should happen
1. We insert vi address instead of array elements as in case of NIC
2 there should be option jump option after one test on certain condition
what u will suggest to make my current project gernalized so that we can have test vi for different instruments then only by change instrument selection the v can select the test.
about attachment
labview 8,2
internet toolkit
run Meup-Top -UI.vi
