limited version of testsatnd
i m trying to make limited version of  test stand .
i already  bulid a project for NIC testing.
i want to generelized this   in which following things should happen
1.  We insert vi address instead of array elements as in case of   NIC
2  there should  be option  jump option after one test on certain condition
what u will suggest to make my current project gernalized so that we can have test vi for different instruments then only by change instrument selection the  v can select the test.
about attachment
labview 8,2
internet toolkit
run  Meup-Top -UI.vi
(2,575 Views)
Hi Ezzemon,
I've reviewed your vi. There are a lot of parts missing that are custom for your specific vi.
1. Can you clarify what you mean by inserting a vi address instead of an element? You could open a file and have the address be an input on the front panel.
2. To skip an option you may want to use a case structure. The default could be do the option but if it has a specific case then the code knows to skip that step.
To generalize your project for a certain set of instruments, you could add another case structure that is dependent on the instrument selected on your front panel.
Hillary E
(2,546 Views)
