limiting directory user can open
Is it possible to limit the directory a user can open using the File Dialog (or similar) vi? I want the user to be able to read from,and write to, a file for loading the data to/from a PC, but only want the user to be able to do it from an external floppy drive. Baseline files exist on the PC that I do not want the user to overwirte. It seems you can use the File function to allow the user to start at a directory that you want, but once this function opens, the user can then browse to anywhere on the PC. Can this browsing be limited to only specific directories?
Thanks.
(3,052 Views)
I don't think it is possible with the standard file browser. It is a standard windows component and a user can read or write to folders according to the security permissions of the operating system.
(3,052 Views)
dave h wrote in message news:<50650000000800000076020100-1079395200000@exchange.ni.com>...
> directories?
> Thanks.
You have two options: 1. Write your own File Dialog VI, or 2. U
se the
built-in one and then check the result, if the user has selected
anything other than 'A:', loop back and force the user to select
again.
Paul Cardinale
(3,052 Views)
BEWIN is correct in his response: the file browser used in LabVIEW is a standard Windows component tied to the operating system's security permissions. However, through the power of LabVIEW this can be overcome.
Attached below, you will find a VI that I wrote in LabVIEW 7.0 which allows a user to specify a root path and select a file under that root path. The VI then returns the selected file. It prohibits a user from browsing in any directory outside the root path and acts as a protected version of the File Dialog VI.
Some information about specifics to this program:
1) Only a file can be returned; a selected directory gets stepped into rather than returned.
2) If "Parent Directory" is selected while in the specified root directory, the VI remain
s in the root directory (this is the protection feature).
3) A user is not permitted make any selections in an empty directory; they must go back to the parent directory or quit.
4) If the VI is quit before a file is selected, is returned.
All of these attributes can be easily modified in the block diagram.
Eric Sulzer
http://www.ni.com/ask
E. Sulzer
(3,052 Views)
